Mounting Accessories
Dovetail 335 & Risers
SKU: PEG-DOV335 & PEG-RISER-25
Meet the new PegasusAstro Dovetail 335mm in length.
Designed with multiple mounting holes, it accommodates a wide range of accessories and rings for your telescope. Precision-machined from high-grade 6061 aluminum, it provides exceptional strength and stability, ensuring your telescope and accessories are securely mounted.
For additional flexibility, you can pair it with our optional risers, SKU: PEG-RISER-25 of 25mm height each, to elevate your telescope tube as needed.
Universal Clamp
SKU: PEG-USCLAMP
Upgrade your telescope setup with our Universal Single Clamp (PEG-USCLAMP)!
Just use the 4 x M3 screws provided to attach it directly onto the Ultimate Powerbox v3.
Once secured, you can easily mount it onto your telescope assembly with the dual VIxen and Losmandy 3” clamp.
A-Plate
SKU: PEG-APLATE
Accessories Plate can be mounted on top of your telescope and accept a wide range of devices such as one of our Powerbox Series, a USB Hub, or any other device in the market.
The plate is made of black anodized aluminium and its thichkness is 5mm. Weight is 400g
The plate includes multiple rails allowing you to orient devices at your preference.
Bolts included in the box : 2x M3x12mm, 2x M6x10mm, 2x M3x16mm, 2x M3x8mm
Spider Clamp
SKU: PEG-SPIDERCLAMP
Pegasus Astro Spider Clamp (PEG-SPIDERCLAMP) is your solution for securing and safeguarding power and data cables against snags and connector damage.
Specifically designed for the Ultimate Powerbox v3, this clamp ensures cable protection. Plus, it offers the convenience of directly plugging and securing small-factor PCs like the Intel NUC, MELE, or any VESA-compatible device (75x75mm and 100x100mm) onto the UPBv3.
Ultimate Powerbox v3 onto Universal Clamp
Pegasus Shoe
SKU: PEG-SHOE
Easily mount your * Pocket Powerbox Advance , * Pocket Powerbox Micro or DewMaster2 to your telescope setup using the PEG-SHOE. This convenient attachment ensures a secure and stable fit, allowing you to organize your gear efficiently while keeping your power management system within easy reach during observation sessions.
* Compatible only with new Blue & Black enclosure.
2 x M3x8mm screws are included.
Tripod Rubber Footpads
SKU: PEG-FOOTPAD-TRPD
New rubber footpad set (3 pcs) designed for hard surfaces. (concrete, tiles etc)
Easily upgrade your carbon tripod with these three high-grip pads, enhancing the stability of your tripod on these surfaces!
Fully compatible with NYX101 and NYX88 carbon tripod, as well as other carbon tripod models in the market.
