Power & Motor Cables
We offer the following cables types:
You can order them from all of our dealers. Please ask for the SKU name.
Cigarette Lighter Adapter to DC 2.1mm
SKU: CIGLIGHT-ADAPTER21
- Compatible with Pocket Powerbox, Pocket Powerbox Micro, Pocket Powerbox Advance, FocusCube v1/v2, Prodigy Microfocuser.
- DC 2.1mm jack
- Length 1.8m /6 feet
- 10Amps Fuse
Cigarette Lighter Adapter to DC 2.5mm
SKU: CIGLIGHT-ADAPTER25
- Compatible with Ultimate Powerbox v1, DewMaster
- DC 2.5mm jack
- 10Amps Fuse
Cigarette Lighter Adapter to XT60
SKU: CIGLIGHT-ADAPTERXT60
- Compatible with Ultimate Powerbox v2 and v3
- XT60 jack
- 10Amps Fuse
Cigarette Lighter Adapter to GX12
SKU: CIGLIGHT-ADAPTERGX12
- Compatible with Pegasus NYX-101 and Skywatcher EQ6 mounts.
- GX12 jack
- 10Amps Fuse
Please note that this cable type is compatible with:
- Pegasus Astro NYX-101
- Pegasus Astro NYX-88
- Skywatcher AZ-EQ5
- Skywatcher AZ-EQ6 Pro
- Skywatcher EQ6-R Pro
- Skywatcher EQ6-R
- Skywatcher EQ8–RH
- Skywatcher EQ8-R
Power cable for GX12 socket type mounts
SKU: PEG-CABL-GX12
- Compatible with all Powerbox Series
- Skywatcher AZ-EQ5
- Skywatcher EQ6-R
- Skywatcher EQ8-R
Skywatcher EQ8–RH
Power cable for Skywatcher EQ8
SKU: PEG-CABL-GX16 (was PEG-CABL-EQ8)
- Compatible with Powerbox Series
This is only for EQ8 (EQ8-R & RH requires the smaller GX12 plug – check cable above)
Single 2.1mm to 2.5mm Cable for Intel NUC 0.5m
SKU: PEG-CABL2125NUC
- Male 2.1mm x 5.5mm to Male 2.5mm x 5.5mm
- Max current: 5A
- Length: 0.5m /1.6 feet
- Suitable for Intel NUC
Pack of 2 x 2.1 to 2.1 Silicon Cables 0.5m – Ultra Flexible for Cold Environments
SKU: PEG-CABL-2105-FLEX
- Male 2.1mm x 5.5mm to Male 2.1mm x 5.5mm
- Max current: 5A
- Silicon (Resistant to Cold and Heat)
- Ultra-Flexible Cables – Perfect for Extreme Cold!
Pack of 2 x 2.1 to 2.1 Silicon Cables 1.0m – Ultra Flexible for Cold Environments
SKU: PEG-CABL-2121-FLEX
- Max current: 5A
- Length: 1.0m /3.2 feet
Pack of 2 x 2.1 to 2.5 Cables 1.5m
SKU: PEG-CABL-2125
- Max current: 5A
- Length: 1.5m /5 feet
Pack of 4 x 2.1 to 2.1 Cables 1.0m
SKU: PEG-CABL-2121
- Max current: 5A
- Length: 1m / 3 feet
Pack of 2 x 2.1 to 2.1 Cables 0.5m
SKU: PEG-CABL-2105
- Max current: 5A
Pack of 2 x 2.1 to 2.1 Cables 1m Angled
SKU: PEG-CABL-2121-90D
- Max current: 5A
Pack of 2 x 2.1 to 2.1 Cables 0.5m Angled
SKU: PEG-CABL-2105-90D
- Male 2.1mm x 5.5mm to Male 2.1mm x 5.5mm Angled 90 deg
- Max current: 5A
Adapter 2.5 x 5.5mm female to XT60 female for UPBv2 and UPBv3
SKU: PEG-ADAPT-25XT60
If you own a 2.5mm PSU you can use this adapter to power your UPBv2 / UPBv3
- Female 2.5mm x 5.5 to XT60 female
- Max current: 15A
- Length: 0.3m / 1 ft
Cable GX12-2 to XT60 female for NYX-101/88
SKU: PEG-CABL-GX12XT60
You can use this cable to provide power from NYX-101/88 Output to a Powerbox that has an XT60 socket (e.g Ultimate Powerbox v2, v3)
- Cable GX12-2 to XT60 Female (NYX-101, NYX-88) 1.0 meter
- Max current: 10A
- Length: 1.0m / 3ft
Adapter 2.5 x 5.5mm female to GX12 (For NYX-101/88)
SKU: PEG-ADAPT-25GX12
If you own our 2.5mm PSU 12V/10A you can use this adapter to power your NYX-101/88 mount
- Female 2.5mm x 5.5 to GX12-2
- Max current: 10A
- Length: 0.3m / 1ft
Skywatcher AZ-EQ5
Skywatcher EQ6-R
Skywatcher EQ8–RH
Skywatcher EQ8-R
Adapter 2.1 x 5.5mm female to GX12 (For NYX-101/88)
SKU: PEG-ADAPT-21GX12
If you own our 2.1mm PSU 12V/10A you can use this adapter to power your NYX-101/88 mount
- Female 2.1mm x 5.5 to GX12-2
- Max current: 10A
Skywatcher AZ-EQ5
Skywatcher EQ6-R
Skywatcher EQ8–RH
Skywatcher EQ8-R
Pack of 2 cables 2.1m Male to RCA Female 15cm
SKU: PEG-CABL-21MRCAF
2 x 2.1mm Male to RCA Female.
When you need to plug your RXA dew heaters to a 2.1mm socket.
- Max current: 5A
- Length: 15cm / 0.5 ft
Cable 2.1mm Male to USB-C 30cm
SKU: PEG-CABL-21MUSBC
Length: 30 cm / 1 ft
2.1mm Male to USB-C
Suitable for MELE mini PC.
IMPORTANT NOTE
DO NOT PLUG THIS CABLE TO A VOLTAGE OUTPUT ABOVE 5V AND PROVIDE POWER TO DEVICES THAT DO NOT SUPPORT VOLTAGES ABOVE 5V (USB VBUS VOLTAGE)
Stepper Motor Cable for Starlight HSM Motor
SKU: PEG-CMOT-HSM
RJ45 to RJ45 (Custom Pinout)
- Length: 1m
Compatible with:
- Starlight HSM Motors
- Starlight POSI Drive Motor
- Optec QuickSync FT Motor
Stepper Motor Cable for Starlight MSM / Rigel Motor
SKU: PEG-CMOT-MSM
RJ45 to RJ11 (Custom Pinout)
- Length: 1m
Compatible with:
- Starlight MSM Motors
- Rigel nStep Motors
Stepper Motor Cable for Moonlite / Lakeside / Robofocus
SKU: PEG-CMOT-RJ45DB9
RJ45 to DB9 (Custom Pinout)
- Length: 1.8m
Compatible with:
- Lakeside Motors
- Robofocus Motor
- MoonLite High Resolution Stepper Motor
