EQDIR USB Stick for EQMOD
Our new compact EQDir USB Stick Adapter for EQMOD allows direct connection of Skywatcher HEQ5/PRO Syntrek/PRO, NEQ6 Syntrek/PRO, AZ EQ6-GT and EQ8 mounts to your PC or laptop. With this adapter you can remote control your Skywatcher mount directly via PC. No handbox controller is needed and the device is perfect for remote observatories.
Compact size
It is a USB stick!
EQDIR heart is based on FTDI USB to Serial Chip
The device uses an original FTDI chip. This chip is fully compatible and functional with Windows XP, 7 , 8, 10, 11, OSX, Linux. There is no need to install external drivers as Windows Update will install the latest FTDI driver. Just plug it in your PC and play.
PegasusAstro EQDIR
EQDIR adapter for DB9 type mounts
Choose the appropriate model (DB9 or RJ45) for your older EQ mount. You can use the same device in both of your mounts. Just attach the RJ45 to DB9 adapter and you are ready to go.
Mount Compatibility
RJ45 Cable type
  • Skywatcher EQ3 PRO
  • Skywatcher EQM-35 PRO
  • Skywatcher AZ EQ5-GT
  • Skywatcher HEQ5
  • Skywatcher HEQ5 Pro
  • Skywatcher AZ-HEQ5
  • Skywatcher AZ EQ6-GT
  • Skywatcher EQ6-R
  • Skywatcher EQ6-R Pro
  • Skywatcher EQ8
  • Orion Sirius EQ-G Go
  • Orion Sirius Pro AZ/EQ-G
DB9 Cable type
  • Skywatcher EQ6
  • Skywatcher NEQ6
  • Orion Atlas EQ-G Computerized GoTo
FAQ
