EZY Focus Hand Controller
Experience unparalleled precision with the EZY Focus Hand Controller, designed to deliver exceptional control over your motorized focuser. Say goodbye to vibrations and elevate your focus routine to a new level of smoothness and accuracy!
Compatible with:
  • Ultimate Powerbox v2
  • Ultimate Powerbox v3
  • Prodigy Microfocuser
  • FocusCube v3
EZYFocusHandController
Digital Encoder with a Push button
The rotary knob simulates the knob of your focuser. Rotate the digital knob and easily focus! Precision can be achieved when you press the knob inside. Speed is reduced to 1:10 just like the fine focus knob of your focuser! Click it again to switch to coarse focus.
Pushbuttons to Focus IN and OUT
Two additional buttons “<< and >>” allows you to move the focuser IN or OUT by the exact and preconfigured step count you have set in the EZY Focus menu. Every time you press the button an audible beep confirms the motor movement.
Can work simultaneously with PC motor operation
Just plug the hand controller in the EXT port of the Ultimate Powerbox v2 or Prodigy Microfocuser and enjoy precision in manual focusing without vibrations. No need to remove the hand controller when you use your PC to control the motor. Both can work in parallel and sync motor position in screen.
Organic LED display with Red Film
A 1.3 inch 128 x 64 pixel Organic LED (red film) screen is used for the device. It will ensure that your night vision will be unaffected.
Additional Information
Display
Large fonts, Legible letters displaying motor position, motor position presets and settings menu
Motor Preset Menu
Main Display
Settings Menu
Bright adjustable red LED light
A large red colored LED is placed in the front of the device, allowing you to use the “EZY Focus Hand Controller” as an astronomical map red light. LED’s brightness can be configured from the device menu.
1 x EZY Focus Hand Controller (with detachable lanyard)
1 x RJ12 to RJ12 cable (1.5m cable length)
Compatible with
  • Ultimate Powerbox v2 and v3
  • FocusCube v3
Compact size
Dimensions: 113mm x 46mm x 25mm , Weight 90 grams
FAQ
