Digital Encoder with a Push button
The rotary knob simulates the knob of your focuser. Rotate the digital knob and easily focus! Precision can be achieved if you press the knob inside. Speed is reduced to 1:10 just like the fine focus knob of your focuser!
Can work simultaneously with PC operation
Just plug the hand controller in the auxiliary port of the FocusCube and enjoy precision in manual focusing without vibrations. No need to remove the hand controller when you use your PC to control the FocusCube. Both can work in parallel.
A LED indicator for each speed
On top of the RJ45 socket, there are two LEDs. Green and Orange indicate running speed: coarse or fine focus.
| 1 x Hand Controller for FocusCube |
| 1 x RJ45 to RJ45 Straight Cable |
