NINA Rel 2.0 RC01 Connection Issues With Pocket Powerbox Advance Gen 2
I can't connect to Pocket Powerbox Advance Gen 2. I am using the Unity SW and am running ASCON 6.6.
Re: NINA Rel 2.0 RC01 Connection Issues With Pocket Powerbox Advance Gen 2
i can confirm the same connection issue exits for the PPBA Gen 1 with NINA 2.0 RC01. While the PPBA connects to the Unity App without problem it suffers to connect to NINA or the ASCOM Diagnostic Tool. See attached Screenshot
- 2022-04-30.png (266.31 KiB) Viewed 7625 times
I also can't connect to the Pocket Powerbox Advance Gen 2 with NINA. I have the following installed:
- NINA 2.0.0.9001
- Pegasus Unity 1.5.84.12
- Pocket Powerbox Setup (v1.18 / Nov 21)
- Ascom Platform 6.6 - 6.6.0.3444
- ASCOM Powerbox Switch Driver v2.3 (Jan/21)
- NINA 2.0.0.9001
I tried with latest NINA and latest Unity.
Everything seems to work fine with any of our ASCOM drivers (including switches and observing conditions).
If you use Unity the below software is not required (you can uninstall it if you want). Unity automatically installs its own ASCOM drivers
