Issue with Pegasus Astro Unity
Eric78
Post by Eric78 »
I am using the new Pegasus Astro Unity with a FocusCube 2 and a Ultimate Powerbox2 and a Motor Focus Kit Universal connected to the Ultimate Powerbox2.
Using Unity software I connect the Powerbox2 and the Motor Focus Kit without issue but can't connect the FocusCube 2.
I get an error message (see attachment).
In the main screen of the software, I can see both hardware.....
Using the FocusCube software, I have no issue, evrything is ok.
Thanks for any advice.
Regards
Re: Issue with Pegasus Astro Unity
Please check any ERROR logs under Configuration -> Logs -> Server (tab)
You can click refresh button and check the ERROR (in red) logs at the end of the file
Eric78
Post by Eric78 »
You will find part of "log" with some ERROR message.
Hope this help.
Regards
Eric
You can expand each error message pressing the + symbol on the left.
We need to read the message of each error line.
Eric78
Post by Eric78 »
Here is the details.
Let me know if it's ok ; I could do more test........
Eric78
Post by Eric78 »
Eric78
Post by Eric78 »
Hi Eric,
Thanks for the screenshots.
We found the bug and we'll provide a fix by tomorrow.
Eric78
Post by Eric78 »
Greats... Thanks a lot
I will download the fix and give it a try in the next days.
Thanks again
Regards
Eric
Eric78
Post by Eric78 »
I tried the new Unity software this evening but still can't connect the FocusCube2....
Here is the log with ERROR....
Thanks in advance
Eric
Eric78
Post by Eric78 »
Hi Eric,
It is better to schedule an anydesk session so we can have a look of what is going on.
Please reach us at support@pegasusastro.com
