Winn 11 firmware update issues
Crossroads
Post by Crossroads »
Have issues to update the firmware under Win 11. Firewall settings are set according to suggestions. I removed double entry of Peg.server. However, I need to do that after each update of unity software.
Anyway, it does not solve the problem. Starting the firmware update ends in an endless loop "updating", progress stays at 0%. After a minute or two I receive an error with loads of details of different dlls listed. For any reason I cannot attache the
file (board attachment quota reached?)
PC is a brand new mini PC runnig WIN 11 Pro. I did not have this problems with win 10 by the way.
Cheers,
Crossroads
Crossroads
Re: Winn 11 firmware update issues
Guys from Pegasus: Any ideas? No Ideas? I still receive error while trying to upload a file: Quote exceeded. Could you fix this (at least?)?
rodolgo
Post by rodolgo »
Having the same issues, running on Win 10.
NYX f/w version is 1.29.2. Unity tells version 1.30.2 si available.
The update process crashes systematically.
I had the same problem with the previous f/w version - got sorted through support who sent me the f/w file over to be uploaded to the mount. Was successful.
Now need to repeat this... :(
rodolgo
Post by rodolgo »
Hi
Update - the Pegasus web site provides an alternative way to update the NYX mount firmware: https://pegasusastro.com/nyx-101-firmware-update/, in the "Using Web Browser" section.
Tested successfully on my end.
