USB Settings following a power cycle
Discussion about the UCH, our industrial grade, smart USB3 Hub
DRich66
Post by DRich66 »
Are the USB Settings (which ports are on, which ports are off) remembered by the Control Hub if the Hub is powered off or there is a power cut ? or do the settings have to be reentered upon power up which would be a pain !
I saw in another posting that there is a query over the behaviour of Port 1 being possibly different from other ports ?
Thank you, David (UK)
Re: USB Settings following a power cycle
You can setup the initial (boot) state of USB ports
