USB Not Recognised
Bryneth
USB Not Recognised
Post by Bryneth »
A new PB micro is not connecting to my PC's. Unknown USB Device (Device Descriptor Request Failed). Tried different PC's same issue. Tried several USB cables same issue. The device initially worked ok, but the issue stated happening with increasing frequency over an evening whilst putting together my rig. If powered without USB I get a red led flash, then off for 3 seconds, then flashes again, then stay permanently on - which it what it should do I believe. If the usb is plugged in first then powered, no LED comes on. PC device manager reports the issue as above.
Have tried all suggestions in https://www.freecodecamp.org/news/devic ... or-solved/
but no help.
FYI you may recall my name as this is the second issue I've had recently, the previous issue was with the rotator which was solved with a firmware download to the device. I was very happy with the support and device so bought the PB Micro to complete the rig.
Anything I can do here? Or is device faulty?
