Threads lenght for Falcon Rotator adapters
Alfons
Post by Alfons »
I have the first model of Falcon Rotator. The adapters are defined on your website with threads of 4 mm in length, but they are actually 6 mm long, which makes them difficult to mate with some female adapters.
My question is: Is it correct on the new Rotator model that has its adapters with thread length of 4mm. as described on your website, or they can be longer ?
Wheeljack
Re: Threads lenght for Falcon Rotator adapters
Post by Wheeljack »
Think you will get a better response if you email them, these forums are more meant as user-forums than support-forums.
You've probably gotten an answer by now, but just in case; I have the V2 of the rotator, and can confirm that the adapters have a threadlength of 4mm.
peanutsunless
Post by peanutsunless »
If the website indicates that the adapters have a thread length of 4mm, that's usually the standard provided by the manufacturer. It would be best to check directly with the manufacturer or consult the most recent product documentation for the most accurate information. It sounds like you're referring to specific technical details about the Rotator model from a manufacturer or product line.
