Power Box Micro Error Message
dja787
Post by dja787 »
I am having issues with my setup on a Hyperstar with a ASI2600MC Pro. The problem has been a camera, but I swapped for a different camera and had the same problem, so I know it is something else. I am running a MiniPC, which I suspect, BUT I have had a couple cases where an error message popped up from my Power Box Mini, but they went away before I could even read them.
I have read there is a log file, but on my Unity program under CONFIGURATION, it does not show LOGS. Am I missing something? In troubleshooting, I have a second Power Box Mini and I will swap it out to see if I am having any power issues from the Power Box Mini.
Thanks for your help.
Dave
bettyking
Re: Power Box Micro Error Message
Post by bettyking »
The log file you mentioned may not be accessible through the Unity program's configuration. Many astrophotography devices have their own dedicated logging mechanisms. Check if the ASI2600MC Pro camera or the Power Box Mini have any built-in logging functionality that you can access directly, either through their software or by checking the device's documentation.
