Can the PPBA be monitored on iPad?
PaulInNorthMichigan
Post by PaulInNorthMichigan »
I am going through the considerations of purchasing an ASIAIR Pro to monitor my evening imaging remotely on my iPad.
I believe there is no compatibility for the ASIAIR Pro to display the PPBA settings, however I believe that there would be no issue for the ASIAIR Pro in receiving power through the PPBA. Correct me if I am wrong. (I have seen that the standard PPB was able to transfer power successfully to the ASIAIR device)
My question would be; is there any way for an iPad to read in the settings of PPBA independently? I guess the main thing that I would want to monitor would be the dew heaters.
Presently I am monitoring everything via INDI on my MacBook Pro, but I like the apparant simplicity of the ASIAIR Pro. I absolutely don't want to give up my PPBA as it does exceptionally well in routing all of the connections properly.
Re: Can the PPBA be monitored on iPad?
Check if ASIAIR has the INDI driver installed for the PPB Advance or any PPB.
Unfortunatelly the only way to control the PPBADV is via INDI.
