Small Factor PC Base Plate for UPBv2 and VESA 75x75
sbenz
Post by sbenz »
Hello all,
I have run into some problems with the Small Factor PC Base Plate for UPBv2.
I would like to connect base plate with a Mini PC via the VESA 75x75 standard, but the holes of the VESA adapter do not match with the holes in the small factor base plate. They are off by just a few mm.
Is this a manufacturing mistake in my base plate, or is the base plate not designed to match to a standard VESA 75x75 adapter?
Thanks,
Stefan
Re: Small Factor PC Base Plate for UPBv2 and VESA 75x75
It was not designed to match the VESA standard
sbenz
Post by sbenz »
Hi Evans,
thanks for the info, that's too bad.
How about adjusting the base plate in a second version so that it matches VESA 75x75?
The adjustment would be really minor, just a few mm shift of the long slots.
Stefan
Thanks for the feedback.
Will check it for the next production batch /revision
