Power & Data Distribution
Pocket Powerbox Micro
Pocket Powerbox Micro  is suitable for the “grab and go” astrophotographer. Device can provide up to 10Amps of power, has a sufficient number (4) of 12V Outputs, Two Dew Heater Channels, an adjustable voltage power output and an environmental sensor to monitor humidity / temperature (dew point).
Pocket Powerbox Advance
Advance model has all “Micro “features and it is enchanced with a USB3 hub.
Ultimate Powerbox v2
Our flagship powerbox model. A smart industrial grade USB3.1 Hub was added so you can switch on/off each USB port , more power outputs, more dew heaters, α new stepper controller that can drive any stepper motor in the astronomy market
Product Comparison Table
FeatureMicroAdvanceUltimate v2
12V Outputs44 +1 (Adjustable Output set to 12V)4 +1 Always ON Output + 1 (Adjustable Out set to 12V)
(6 in total)
Switchable Outputs1 x 12V channel
(you can switch all ouputs ON/OFF
1 x variable output
1 x 12V channel
1 x variable output
4 Channels x 12V Outputs
(Individual switch of outputs)
Adjustable Regulator
(3, 5, 8, 9, 12 Volt)
(3,4,5,6,7,8,9,10,11,12 Volt)
EXT Port (for peripherals)
Dew Heaters2 x Ports
2 x Channels
2 x Ports
2 x Channels
3 x Ports
3 x Channels
Auto Dew Heater Adjustment
Configurable per channel
Stepper Motor Controller
* Can accept external motor controller via EXT port)
* Can also accept external motor controller via EXT port for 2nd motor drive)
Current Delivery (max)10Amps12Amps20Amps
Power SensorsCurrent (12V + Dew Heaters) + VoltageCurrent (12V + Dew Heaters) + VoltageIndividual current meters for each output
Environmental Sensor
(included)
(included)
(included)
USB Hub
4 x USB3.0 Hub (unmanaged)
6 x USB3.1 Industrial Grade Hub.
Each USB Port can turn ON/OFF via software
Standalone Software
ASCOM SoftwareObserving Conditions,
Switches
Switches
Switches,
Focus
DC Input Socket2.1mm circular2.1mm circularXT60
ProtectionsReverse Polarity, 12V Overcurrent, OvervoltageReverse Polarity, 12V Overcurrent, OvervoltageReverse Polarity, 12V Overcurrent isolation per port, Overvoltage
Watchdog
Dimensions66mm x 66mm x 20mm
Weight 90 grams
100mm x 73 xx 25mm
Weight 250grams
120mm x 100mm x 30mm
Weight 400grams
