Focus accurate and fast your Celestron SCT telescope using our powerful motor focus kit SCT. This high resolution geared box has a 0,06 degree step size can can easily lift more than 6 Kg (per cm). Its high torque is suitable for lifting heavy imaging equipment. Moreover motor’s gearbox has a low backlash which can easily tuned using backlash compensation in imaging software. An RJ45 socket pinout can be easily converted to a compatible pinout with Moonlite and Robofocus controllers.
Pulley and Belt design allows the motor to stay away from your filter wheel (and not collide with it) when you use a focal reducer. Its sophisticated bracket design can fit to all Celestron SCTs
Note: You will need a stepper controller to drive the motor. Check our Dual Motor Focus Controller
A special shaped blue anodised aluminium bracket, hard to bend, can be attached to all Celestron SCT telescopes. We have successfully installed it on:
- Celestron EdgeHD 8, 9.25 , 11, 14
- Celestron SCT C6, C8, C925, C11, C14
What the Motor Focus Kit SCT package includes:
- High resolution geared stepper motor (Step Angle 7.5, Deg 120, Gear Ration 1:120). Its gearbox has very low backlash and high torque suitable to focus in micron scale.
- Blue Aluminium Anodised Bracket for Celestron SCT Telescopes
- 20cm 2GT Timing Belt
- 13 mm Pulley 2GT (6”,8”,9.25”) or 22mm Pulley 2GT (11” ,14” Celestron)
- Bolts
Note: Controller is not included in the Motor Focus Kit SCT package
Pegasus Stepper Motor Technical Specifications
Step Angle (Deg) | 7.5 / 120 = 0.0625 |
Gear Ratio | 1:120 |
Phases | 4 (Unipolar Motor) |
Voltage | 12V DC |
Current (A) | 0.27 |
Pull-in Rate (PPS) | 400 |
Pull-in Torque (N.cm) | 60 (100pps) |
Weight | Stepper Motor, SCT Adapter & Motor Pulley / Belt weight in total 300g |
