Unity do not detect UPBV2
Fred2812
Post by Fred2812 »
I have recently installed unity platform to connect UPBV2, running windows 10.
I performed a clean désinstall of previous version of UPBV2 software, I performed the same with unity platform and reinstalled but:
UPBV2 is not detected. It seems that peg.server doesn't start although peg.ui is running.
When starting Unity, Peg.Ui shows up in task manager, but peg.server don't show up even for a few seconds
Device manager shows the port com with UPBV2 connected.
It is connected generic usb hub 2.1
=========================== USB Port7 ===========================
Connection Status : 0x01 (Device is connected)
Port Chain : 1-6-7
========================== Summary =========================
Vendor ID : 0x0403 (Future Technology Devices International Limited)
Product ID : 0x6015
USB Version : 2.0 -> but Device is Full-Speed only
Port maximum Speed : High-Speed
Device maximum Speed : Full-Speed
Device Connection Speed : Full-Speed
Self powered : yes
Demanded Current : 90 mA
Used Endpoints : 3
======================== USB Device ========================
+++++++++++++++++ Device Information ++++++++++++++++++
Device Description : USB Serial Converter
Device Path 1 : \\?\USB#VID_0403&PID_6015#UPB25QYIZ4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} (GUID_DEVINTERFACE_USB_DEVICE)
Device Path 2 : \\?\USB#VID_0403&PID_6015#UPB25QYIZ4#{219d0508-57a8-4ff5-97a1-bd86587c6c7e} (GUID_DEVINTERFACE_FOR_D2XX)
Kernel Name : \Device\USBPDO-11
Device ID : USB\VID_0403&PID_6015\UPB25QYIZ4
Hardware IDs : USB\VID_0403&PID_6015&REV_1000 USB\VID_0403&PID_6015
Driver KeyName : {36fc9e60-c465-11cf-8056-444553540000}\0007 (GUID_DEVCLASS_USB)
Driver : \SystemRoot\system32\drivers\ftdibus.sys (Version: 2.12.36.3 Date: 2022-11-10)
Driver Inf : C:\WINDOWS\inf\oem42.inf
Legacy BusType : PNPBus
Class : USB
Class GUID : {36fc9e60-c465-11cf-8056-444553540000} (GUID_DEVCLASS_USB)
Service : FTDIBUS
Enumerator : USB
Location Info : Port_#0007.Hub_#0003
Location IDs : PCIROOT(0)#PCI(1400)#USBROOT(0)#USB(6)#USB(7), ACPI(_SB_)#ACPI(PC00)#ACPI(XHCI)#ACPI(RHUB)#ACPI(HS06)#USB(7)
Container ID : {b2b33d98-d962-5398-af57-db00fd444a86}
Manufacturer Info : FTDI
Capabilities : 0x94 (Removable, UniqueID, SurpriseRemovalOK)
Status : 0x0180600A (DN_DRIVER_LOADED, DN_STARTED, DN_DISABLEABLE, DN_REMOVABLE, DN_NT_ENUMERATOR, DN_NT_DRIVER)
Problem Code : 0
Address : 7
Power State : D0 (supported: D0, D3, wake from D0)
Child Device 1 : USB Serial Port (COM4)
Device Path 1 : \\?\FTDIBUS#VID_0403+PID_6015+UPB25QYIZ4A#0000#{86e0d1e0-8089-11d0-9ce4-08003e301f73} (GUID_DEVINTERFACE_COMPORT)
Device Path 2 : \\?\FTDIBUS#VID_0403+PID_6015+UPB25QYIZ4A#0000#{4d36e978-e325-11ce-bfc1-08002be10318} (GUID_DEVINTERFACE_SERENUM_BUS_ENUMERATOR)
Kernel Name : \Device\00000066
Device ID : FTDIBUS\VID_0403+PID_6015+UPB25QYIZ4A\0000
Class : Ports
Driver KeyName : {4d36e978-e325-11ce-bfc1-08002be10318}\0002 (GUID_DEVCLASS_PORTS)
Service : FTSER2K
COM-Port : COM4 (\Device\VCP1)
+++++++++++++++++ Registry USB Flags +++++++++++++++++
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\usbflags\040360151000
osvc : REG_BINARY 00 00
---------------- Connection Information ---------------
Connection Index : 0x07 (Port 7)
Connection Status : 0x01 (DeviceConnected)
Current Config Value : 0x01 (Configuration 1)
Device Address : 0x0B (11)
Is Hub : 0x00 (no)
Device Bus Speed : 0x01 (Full-Speed)
Number Of Open Pipes : 0x02 (2 pipes to data endpoints)
Pipe[0] : EndpointID=1 Direction=IN ScheduleOffset=0 Type=Bulk wMaxPacketSize=0x40 bInterval=0
Pipe[1] : EndpointID=2 Direction=OUT ScheduleOffset=0 Type=Bulk wMaxPacketSize=0x40 bInterval=0
Data (HexDump) : 07 00 00 00 12 01 00 02 00 00 00 08 03 04 15 60 ...............`
00 10 01 02 03 01 01 01 00 0B 00 02 00 00 00 01 ................
00 00 00 07 05 81 02 40 00 00 00 00 00 00 07 05 .......@........
02 02 40 00 00 00 00 00 00 ..@......
--------------- Connection Information V2 -------------
Connection Index : 0x07 (7)
Length : 0x10 (16 bytes)
SupportedUsbProtocols : 0x03
Usb110 : 1 (yes, port supports USB 1.1)
Usb200 : 1 (yes, port supports USB 2.0)
Usb300 : 0 (no, port not supports USB 3.0)
ReservedMBZ : 0x00
Flags : 0x00
DevIsOpAtSsOrHigher : 0 (Device is not operating at SuperSpeed or higher)
DevIsSsCapOrHigher : 0 (Device is not SuperSpeed capable or higher)
DevIsOpAtSsPlusOrHigher : 0 (Device is not operating at SuperSpeedPlus or higher)
DevIsSsPlusCapOrHigher : 0 (Device is not SuperSpeedPlus capable or higher)
ReservedMBZ : 0x00
Data (HexDump) : 07 00 00 00 10 00 00 00 03 00 00 00 00 00 00 00 ................
---------------------- Device Descriptor ----------------------
bLength : 0x12 (18 bytes)
bDescriptorType : 0x01 (Device Descriptor)
bcdUSB : 0x200 (USB Version 2.0) -> but device is Full-Speed only
bDeviceClass : 0x00 (defined by the interface descriptors)
bDeviceSubClass : 0x00
bDeviceProtocol : 0x00
bMaxPacketSize0 : 0x08 (8 bytes)
idVendor : 0x0403 (Future Technology Devices International Limited)
idProduct : 0x6015
bcdDevice : 0x1000
iManufacturer : 0x01 (String Descriptor 1)
Language 0x0409 : "Pegasus Astro"
iProduct : 0x02 (String Descriptor 2)
Language 0x0409 : "UPBv2 revD"
iSerialNumber : 0x03 (String Descriptor 3)
Language 0x0409 : "UPB25QYIZ4"
bNumConfigurations : 0x01 (1 Configuration)
Data (HexDump) : 12 01 00 02 00 00 00 08 03 04 15 60 00 10 01 02 ...........`....
03 01 ..
------------------ Configuration Descriptor -------------------
bLength : 0x09 (9 bytes)
bDescriptorType : 0x02 (Configuration Descriptor)
wTotalLength : 0x0020 (32 bytes)
bNumInterfaces : 0x01 (1 Interface)
bConfigurationValue : 0x01 (Configuration 1)
iConfiguration : 0x00 (No String Descriptor)
bmAttributes : 0xC0
D7: Reserved, set 1 : 0x01
D6: Self Powered : 0x01 (yes)
D5: Remote Wakeup : 0x00 (no)
D4..0: Reserved, set 0 : 0x00
MaxPower : 0x2D (90 mA)
Data (HexDump) : 09 02 20 00 01 01 00 C0 2D 09 04 00 00 02 FF FF .. .....-.......
FF 02 07 05 81 02 40 00 00 07 05 02 02 40 00 00 ......@......@..
---------------- Interface Descriptor -----------------
bDescriptorType : 0x04 (Interface Descriptor)
bInterfaceNumber : 0x00 (Interface 0)
bAlternateSetting : 0x00
bNumEndpoints : 0x02 (2 Endpoints)
bInterfaceClass : 0xFF (Vendor Specific)
bInterfaceSubClass : 0xFF
bInterfaceProtocol : 0xFF
iInterface : 0x02 (String Descriptor 2)
Data (HexDump) : 09 04 00 00 02 FF FF FF 02 .........
----------------- Endpoint Descriptor -----------------
bLength : 0x07 (7 bytes)
bDescriptorType : 0x05 (Endpoint Descriptor)
bEndpointAddress : 0x81 (Direction=IN EndpointID=1)
bmAttributes : 0x02 (TransferType=Bulk)
wMaxPacketSize : 0x0040 (64 bytes)
bInterval : 0x00 (ignored)
Data (HexDump) : 07 05 81 02 40 00 00 ....@..
bEndpointAddress : 0x02 (Direction=OUT EndpointID=2)
Data (HexDump) : 07 05 02 02 40 00 00 ....@..
----------------- Device Qualifier Descriptor -----------------
Error : ERROR_GEN_FAILURE (because the device is Full-Speed only)
-------------------- String Descriptors -------------------
------ String Descriptor 0 ------
bLength : 0x04 (4 bytes)
bDescriptorType : 0x03 (String Descriptor)
Language ID[0] : 0x0409 (English - United States)
Data (HexDump) : 04 03 09 04 ....
------ String Descriptor 1 ------
bLength : 0x1C (28 bytes)
Data (HexDump) : 1C 03 50 00 65 00 67 00 61 00 73 00 75 00 73 00 ..P.e.g.a.s.u.s.
20 00 41 00 73 00 74 00 72 00 6F 00 .A.s.t.r.o.
------ String Descriptor 2 ------
bLength : 0x16 (22 bytes)
Data (HexDump) : 16 03 55 00 50 00 42 00 76 00 32 00 20 00 72 00 ..U.P.B.v.2. .r.
65 00 76 00 44 00 e.v.D.
------ String Descriptor 3 ------
Data (HexDump) : 16 03 55 00 50 00 42 00 32 00 35 00 51 00 59 00 ..U.P.B.2.5.Q.Y.
49 00 5A 00 34 00 I.Z.4.
I would really appreciate some help!
Fred
