"Unity Platform > FocusCube" display issue
JST200
Post by JST200 »
This is not a serious problem, but the "Unity Platform > FocusCube" display has a problem with the "Motor Profile > Backlash" and "Speed" entry boxes.
They are too small to display double digit entries, never mind triple digits:
Screenshot 2023-03-08 112335.jpg (219.05 KiB) Viewed 3678 times
The above is a screenshot of an RDP session, so it is using the resolution of the my Laptop. My laptop resolution is:
Screenshot 2023-03-08 113437.jpg (149.19 KiB) Viewed 3678 times
It also happens when I run the "Unity Platform > FocusCube" on my laptop (i.e. not over RDP).
Cheers, Jim :)
P.S. Just to let you know...
I've now tested the fix for my firmware update fail, that you very kindly fixed for me.
Now I have adjusted all the appropriate settings, to allow for the change from using using 1/2 steps to full steps, everything is working well.
Indeed I think the "APT > Auto Focus Aid" is working even better than it did. This is is quite a feat, as it was almost perfect before! :D
so once again, thanks for your help :D
Re: "Unity Platform > FocusCube" display issue
You can now configure the layout and custom-make your own layout template.
I believe this was the best choice to have flexibility in dashboard window layout.
