Hi
Just getting started with PPBA.
Overall impression is positive so far.
I can access the PPBA with a PC which allows me to change and read settings.
However, I wish to operate without a PC when imaging, and I cannot figure
out how to force the PPBA to turn on the Dew heaters when it boots without
a computer. I've tried checking and unchecking Auto Dew, Full etc but nothing seems to stick.
Whatever I do, when it is powered on the dew heaters are off.
Help appreciated.
Cheers, Des
How to make dew heaters stay on in standalone mode
Re: How to make dew heaters stay on in standalone mode
I too would like to know if this feature is possible on a PB Micro. If I tell the device to use 'full on' or any other setting for dew heater output it is reset upon a reboot. It seems the only config that is stored is either auto-dew off with no dew-heater output, or auto-dew on letting the on-board algorithm to handle the dew control output.
Would changing the 'aggressiveness' of the auto-dew ensure that they are on at all times? (if it was set to full aggressiveness)
Both (aggresiveness and auto-dew) is stored in memory and ALWAYS retrieved on boot of both devices (PPB Advance and Micro).
Sure these are retrieved on boot of the device, but how does one configure the unit to for example: Always boot to 50% ON.
I only mentioned "aggressiveness" because I think the "thought process" of the controller for auto-dew is a mystery and I was hopeful that "full agressiveness" might actually just be what the OP is looking for (which is to have the dew controller always ON at boot).
Is this the case?
Is this the case?
I'm afraid this is not possible with current firmware.
It is advised to use auto-dew and let the sensor do the rest.
I noted your request as a feature request for future firmware releases.
It's not possible even with the latest firmware..professorspock wrote: ↑Wed Mar 24, 2021 10:02 pm Sure these are retrieved on boot of the device, but how does one configure the unit to for example: Always boot to 50% ON.
I only mentioned "aggressiveness" because I think the "thought process" of the controller for auto-dew is a mystery and I was hopeful that "full agressiveness" might actually just be what the positive words and OP is looking for (which is to have the dew controller always ON at boot).
Is this the case?
