Unless i got the last ascom drivers, it is impossible to connect when selecting the device "Pegasus Astro PPB Micro" in NIna. Error message is "Ascom Driver error" , "Unable to connevct to Pegasus Astro PPB Micro". THe same occurs when selecting other Pegasus drivers.
Except for the device "Pegasus Astro powerbox switch" : in tha case the connexion is OK but the informations in the panel ares not appropriate (only one switch appears, gauge informations are not activated...)
Its seems as if that PPB MIcro Ascom driver is not operant..
The same occurs if I previously connect Pegasus PPB softaware, or not.
Drivers and softawares:
Unity Platform
Pocket Powerbox Setup (v1.18 / Nov 21)
ASCOM Powerbox Switch Driver v2.3 (Jan/21)
ASCOM Observing Conditions Driver v1.5 (Jun/20)
Ascom PLatform 6.6
Any idea to solve this issue ?
