Connecting astroberry/raspberry pi and UPBv2
wesm912
Post by wesm912 »
I have the UPBv2 on order. My questions are:
1. How to power the Pi? So far, best answer seems to be to use one of the USB3 ports on the UPB to the USB-C port on the Pi. Port 6? I need 5V/3A for the PI.
2. How to have the UPBv2 act as a USB hub for the Pi? My speculation is to run USB 3.1 B to USB A cable from the PC port on the UPB
3. Given power input in 1, is that sufficient to power ASI 2600 camera (not cooler) and the ASI12mm-S guiding camera off the Pi?
4. The ASI2600MC Pro cooler needs 12V/3A, can I power that off of 1 of the 4 12V pins?
5. My mount (ioptron GEM 28) needs 12V/5A. Can I power that off of 1 of the 4 12V pins? or the always on 12V pin?
If I can do all that, then I have only one cable that connects to the battery and moves around with the mount.
That's it for now.
Wes
Re: Connecting astroberry/raspberry pi and UPBv2
Hi Wes,
Regarding your questions
1) Just plug it into a USB port. Each USB can output the required current for the PI.
2) As you wrote, you need to connect the USB 3.1 B to USB A cable from the PC port on the UPB
3) Yes there is. Each USB port can deliver 2.5A. In practice PI requires less that 2 Amps when it is fully utilized. Practically it consumes less than 1 amp. Check here: https://raspi.tv/2019/how-much-power-do ... asurements
4) Yes
5) Yes
wesm912
Post by wesm912 »
Thanks a lot for your help
//w
wesm912
Post by wesm912 »
Evans wrote: Wed Aug 17, 2022 11:55 am Hi Wes,
4) Yes
5) Yes
Well, I still managed to fry my Pi.
I started off by plugging one end of a USB A->C cable into usb port 6 on the hub, the other end into the usb-c power port on the Pi. Pi booted up, everything looked good.
I then plugged usb 3.0B into the PC port on the hub, and the A end of that cable into one of the USB 3A ports on the Pi.
That's correct, isn't it? Didn't make sense to plug into a usb2 port on the Pi
Started adding devices to the hub, I could see them inside KStars indi control panel on the Pi.
Now, I got adventurous. I'd been reading where the latest models of RPi 4B liked 5V/3.5A power. I thought the USB ports on the UPBv2 were limited to 2.5A. So I got a step-down converter, 12V/5V 3A, and wired it into a 2.1mm plug. I tried booting the Pi off of that, and nothing. I did notice that the USB3 ports, where the cable from the UPBv2 was plugged in, got extremely hot.
Now RPi won't boot at all. So it seems I fried my Pi. Would reversed polarity on the plug have done that?
What polarity plug do the power ports on UPB expect?
Wes
You should have plugged the RPI4 into the USB ports.
If you check this diagram you will see that the MAX consumption that rpi4 has is 950mA.
the 3Amps is an extremes scenario when you have used all 4 USB ports of the RPI4 and each port consumes 500mA or more.
Polarity is always . + center pin tip and gnd the outer shell.
Please check the UPBv2 manual for more information
