Motor Focus Kit Zero (For SCTs) ration
ORethore
Post by ORethore »
Hello
Do you know what is the value in degres of one motor step at the level of the focuser axe (C8 or RASA8 model)?
Thanks for your help!
Olivier
Re: Motor Focus Kit Zero (For SCTs) ration
Unfortunately not sure, as the C8 has its own reduction gear mechanism.
ORethore
Post by ORethore »
Hello
I just want to know the ration between the motor and the focuser axe and the value in degres of one motor step. For the RASA 8 I will find out the reduction.
Please check technical specs table here: https://pegasusastro.com/products/focus ... -for-scts/
For C8 & C9.25
Motor Pulleys have: 16 and 60 teeth
Ratio is 1:3.75
Step Angle: 1.8 deg
You can devide 1.8 deg / 3.75 = 0.48 deg per step.
ORethore
Post by ORethore »
Thank you very much!
Best regards
Olivier
