How many amps are on the 12V UPBV2 ports?
astrodoc
Post by astrodoc »
How does the whole amperage thing work on the 12V output ports on UPBV2? Reason I ask is I want to power a QHY camera that draws a max of 8amps and want to make sure it's safe to use. Also if you have multiple devices on multiple ports how are the amps allocated? Basic electronics I suppose but I'm not an electrician.....just an old country doctor :D
Dave
Re: How many amps are on the 12V UPBV2 ports?
Each output can deliver up to 6Amps (7 peak / spike).
Just plug the camera into one of the 12V outputs and it will work fine! :)
astrodoc
Post by astrodoc »
Great! Thanks!
Dave
