HSM Focuser Not Responding
caruhgah
Post by caruhgah »
Hi:
I recently ordered an ethernet cable to connect to my HSM. I am getting no movement when I use the focuser in the UNITY platform. When I use the HSM with the Optic controller it functions fine. Is there a way to see if the HSM is recognized by the software when it is connected?
Thank you.
MKeyman
Re: HSM Focuser Not Responding
Post by MKeyman »
A standard ethernet cable won't work with the HSM focuser as the wiring is different (I had the same issue). Pegasus has information on their website for you to rewire your existing cable or you can purchase the HSM-specific one
Correct, you need to PEG-HSM-CABLE
