UPB V2 Not Connecting
rkas12
Post by rkas12 »
Hi dear astro-friends,
I have been experiencing quite an annoying issue which I am unable to find a solution despite having tried almost everything. I use W10.
My UPB V2 is not connecting while I press the button - even with the "auto-connect" setting on. I am remotely controlling my rigs with a Lunatico Dragonfly. Here is my workflow :
a ) turn on the PC remotely
b) turn on the UPB V2 remote
Once the PC is up and running, I just try to connect the controller - BUT it does not and "freeze" without any success to connect.
My drivers are all up to date. Firewall rules are set to allow connections with any Pegasus's devices.
I would appreciate any help. Also, is there any way to send you a log, or whatever might help you ?
Thank you very much for your kind support and all the best.
A.
Re: UPB V2 Not Connecting
Please download and use our Unity Platform.
https://pegasusastro.com/downloads/
rkas12
Post by rkas12 »
Well, it’s now working provided I always let the relay on (don’t know what’s causing the freeze but my conclusion is O need to keep the relay on to avoid the issue).
I still haven’t had time to install the plateforme to see if the problem disappears.
