Focus motor kit - big issue with screw set - motor completely unusable
dolguldur
Post by dolguldur »
Dear all,
I recently bought from my astro gear retailer, pegasus motor, so that I can connect it directly to my upbv2 through RJ45. But I realized the set of screw provided in the box did not fitter the actual motor ?
There are only 4 screw with the right diameter/threading that can help secure the motor to the support aluminium plate, those 4 are not even of even length.
But then absolutely nothing fits the second aluminium plate, that is supposed to be secured at 90 degrees of the motor support plate, it makes it completely impossible to use the provided set of plates with the motor.
How can I obtain the proper set of screw to secure everything ?
Can somebody help ?
Thank you in advance for your help.
