Starlight Posi Drive Motor Pin-out
xmetal38
Post by xmetal38 »
Hello. Looks like the recommended p/n for the focus cable for a Starlight Posi Drive is PEG-CMOT-HSM, which is the same as the one for the Hand Stepper Motor HSM. So if I am making my own cable, I can use the pinout diagram for the Starlight HSM20/30/35 - RJ45, correct? Thanks.
Re: Starlight Posi Drive Motor Pin-out
Correct. It should be the same
caruhgah
Post by caruhgah »
xmetal38 wrote: Sat Jan 16, 2021 6:13 pm Hello. Looks like the recommended p/n for the focus cable for a Starlight Posi Drive is PEG-CMOT-HSM, which is the same as the one for the Hand Stepper Motor HSM. So if I am making my own cable, I can use the pinout diagram for the Starlight HSM20/30/35 - RJ45, correct? Thanks.
Hi, I'm curious if this worked for you. I tried and it did not work for me (I may have not wired the cable correctly but I tried twice)...
Thanks.
Matthew
