There is someting fishy going on. Regardless if i have the USB hub software running on my laptop or not i get the following error when starting a sequence with SGP: SGP Switch "pegasus astro - usb control hub-6 is not connected! Aborting sequence. When i click OK to close the message a second popup gives the message: Sequence start needs to modify the state of the ”Peasus astro –USB control hub-6” switch but its not connected! End of sequence actions need to modify the state of the ”Peasus astro –USB control hub-6” switch but its not connected! Continnue anyhow? Yes or No
If i click yes it seems to continnue the sequence as normal but im not sure since its daytime right now.
Using windows 10, starting SGP connecting to mount, camera, guide camera and PHD. Initiating all equipment and slwwing to targets and doing everyting else but starting a sequence is working.
Hope someone can shed some light on this issue. The mount is a SW HEQ5Pro
SGP says the USB hub is not connected
