Unity Software versus Original PPBADV Software
sandconp
Post by sandconp »
I just replaced my GEN 1 box with a GEN 2 box so I am able to use USB Port # 1. I downloaded the Unity Software and it initially did not connect while I had the older software running that I used for the GEN 1 box so it doesn't look like they can both co-exist. As soon as I shutdown the older software for the GEN 1 box, then Unity connected to the GEN 2 box.
Am I suppose to un-install the older software now that I have Unity installed?
I am also not able to run Unity with N.I.N.A 2.0 using the Switch and Weather support which worked just fine when using the older GEN 1 box.
Conrad Sanders
Re: Unity Software versus Original PPBADV Software
No, each software is independent. No need to uninstall something.
Make sure that the port is available when you connect with Unity. If the COM port is used then it will not get discovered by unity.
To be sure 100% reboot the PC and retry.
