As of today I can no longer start Unity. The flash screen is displayed and then closed without the application starting
No windows updates have been installed lately and I have tried all the other suggestions on the forum (reinstall Unity and uninstall Intel USB 3.1 eXtensible Host Controller).
Below are the attached crash logs, please help me, since I cannot image without the hub at my remote observatory
Here are the crash logs:
Faulting application name: Peg.UI.exe, version: 1.5.84.12, time stamp: 0x62c743b5
Faulting module name: KERNELBASE.dll, version: 10.0.22000.132, time stamp: 0xf5a91e93
Exception code: 0xe0434352
Fault offset: 0x0013e7b2
Faulting process id: 0x37b4
Faulting application start time: 0x01d8c47a794900c0
Faulting application path: C:\Program Files (x86)\Pegasus Astro\Unity Platform\Peg.UI.exe
Faulting module path: C:\Windows\System32\KERNELBASE.dll
Report Id: 2255f102-d96c-44f7-9193-4b5dcb97724b
Faulting package full name:
Faulting package-relative application ID:
Application: Peg.UI.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.Exception
at Peg.UI.Core.ConfigurationProvider.AddUpdateAppSettings(System.String, System.String)
at Peg.UI.Core.ConfigurationProvider.set_Theme(Peg.UI.Theming.Theme)
at Peg.UI.Theming.LookAndFeelService.SetSkin(Peg.UI.Theming.Theme)
at Peg.UI.Theming.LookAndFeelService.InitializeSkin()
at Peg.UI.View.Main..ctor(Peg.CoreServices.Abstractions.IoC.IDependencyContainer, Peg.CoreServices.Abstractions.MessageBus.IMessageBusService, Peg.UI.Theming.LookAndFeelService, Peg.UI.Events.IDomainEventService, Peg.UI.Core.WaitScreenService, Peg.UI.Core.IAlertNotificationService, Peg.UI.Infrastructure.UpdateService, Peg.UI.Core.IConfigurationProvider, Peg.CoreServices.Abstractions.Logging.ILoggerFactory)
at DynamicClass.lambda_method(System.Runtime.CompilerServices.Closure, System.Object[])
at Autofac.Core.Activators.Reflection.BoundConstructor.Instantiate()
Exception Info: Autofac.Core.DependencyResolutionException
at Autofac.Core.Activators.Reflection.ReflectionActivator.ActivateInstance(Autofac.IComponentContext, System.Collections.Generic.IEnumerable`1<Autofac.Core.Parameter>)
at Autofac.Core.Activators.Reflection.ReflectionActivator.<ConfigurePipeline>b__11_0(Autofac.Core.Resolving.Pipeline.ResolveRequestContext, System.Action`1<Autofac.Core.Resolving.Pipeline.ResolveRequestContext>)
at Autofac.Core.Resolving.Middleware.DelegateMiddleware.Execute(Autofac.Core.Resolving.Pipeline.ResolveRequestContext, System.Action`1<Autofac.Core.Resolving.Pipeline.ResolveRequestContext>)
at Autofac.Core.Resolving.Pipeline.ResolvePipelineBuilder+<>c__DisplayClass14_0.<BuildPipeline>b__1(Autofac.Core.Resolving.Pipeline.ResolveRequestContext)
at Autofac.Core.Resolving.Middleware.DisposalTrackingMiddleware.Execute(Autofac.Core.Resolving.Pipeline.ResolveRequestContext, System.Action`1<Autofac.Core.Resolving.Pipeline.ResolveRequestContext>)
at Peg.UI.Localization.LocalizationMiddleware.Execute(Autofac.Core.Resolving.Pipeline.ResolveRequestContext, System.Action`1<Autofac.Core.Resolving.Pipeline.ResolveRequestContext>)
at Autofac.Core.Resolving.Middleware.ActivatorErrorHandlingMiddleware.Execute(Autofac.Core.Resolving.Pipeline.ResolveRequestContext, System.Action`1<Autofac.Core.Resolving.Pipeline.ResolveRequestContext>)
at Autofac.Core.Pipeline.ResolvePipeline.Invoke(Autofac.Core.Resolving.Pipeline.ResolveRequestContext)
at Autofac.Core.Resolving.Middleware.RegistrationPipelineInvokeMiddleware.Execute(Autofac.Core.Resolving.Pipeline.ResolveRequestContext, System.Action`1<Autofac.Core.Resolving.Pipeline.ResolveRequestContext>)
at Autofac.Core.Resolving.Middleware.SharingMiddleware+<>c__DisplayClass5_0.<Execute>b__0()
at Autofac.Core.Lifetime.LifetimeScope.CreateSharedInstance(System.Guid, System.Func`1<System.Object>)
at Autofac.Core.Lifetime.LifetimeScope.CreateSharedInstance(System.Guid, System.Nullable`1<System.Guid>, System.Func`1<System.Object>)
at Autofac.Core.Resolving.Middleware.SharingMiddleware.Execute(Autofac.Core.Resolving.Pipeline.ResolveRequestContext, System.Action`1<Autofac.Core.Resolving.Pipeline.ResolveRequestContext>)
at Autofac.Core.Resolving.Middleware.ScopeSelectionMiddleware.Execute(Autofac.Core.Resolving.Pipeline.ResolveRequestContext, System.Action`1<Autofac.Core.Resolving.Pipeline.ResolveRequestContext>)
at Autofac.Core.Resolving.Middleware.CircularDependencyDetectorMiddleware.Execute(Autofac.Core.Resolving.Pipeline.ResolveRequestContext, System.Action`1<Autofac.Core.Resolving.Pipeline.ResolveRequestContext>)
at Autofac.Core.Resolving.ResolveOperation.GetOrCreateInstance(Autofac.Core.ISharingLifetimeScope, Autofac.ResolveRequest)
at Autofac.Core.Resolving.ResolveOperation.ExecuteOperation(Autofac.ResolveRequest)
at Autofac.Core.Lifetime.LifetimeScope.ResolveComponent(Autofac.ResolveRequest)
at Autofac.Core.Container.ResolveComponent(Autofac.ResolveRequest)
at Autofac.ResolutionExtensions.TryResolveService(Autofac.IComponentContext, Autofac.Core.Service, System.Collections.Generic.IEnumerable`1<Autofac.Core.Parameter>, System.Object ByRef)
at Autofac.ResolutionExtensions.ResolveService(Autofac.IComponentContext, Autofac.Core.Service, System.Collections.Generic.IEnumerable`1<Autofac.Core.Parameter>)
at Autofac.ResolutionExtensions.Resolve[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]](Autofac.IComponentContext, System.Collections.Generic.IEnumerable`1<Autofac.Core.Parameter>)
at Autofac.ResolutionExtensions.Resolve[[System.__Canon, mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089]](Autofac.IComponentContext)
at Peg.UI.Program.Main()
Unity not working
Re: Unity not working
Please reach us at support@pegasusastro.com to schedule an anydesk session and investigate the issue.
You should have a problematic dll somewhere in a windows temp directory.
