Unity and SGP (Observing conditions) - no data
rodolgo
Post by rodolgo »
Hi
I'm wondering why observing conditions data don't show up in SGP.
I use "Pegasus Astro Observing conditions" as the driver for Environment in SGP; then connect to it (message box displaying "Driver compatible with UPB, UPBv2..." shows up).
The SGP environment panel displays no data (N/A) in all fields.
Used to work well with the legacy ASCOM drivers...
Any idea?
thanks in advance,
Rodolphe
Re: Unity and SGP (Observing conditions) - no data
If you use Unity, then you have to use the Unity ASCOM driver.
The one you report is the older obs conditions driver for the standalone application
rodolgo
Post by rodolgo »
Thanks for the hint. However it doesn’t seem listed in the driver list… installation issue?
Probably. The ASCOM driver is not registered.
Unity installation registers all available PegasusAstro ASCOM drivers that exist in Unity Package
