Control Focus Cube Maxim Dl/FocusMax
mmart
Post by mmart »
I select the Ascom driver of pegasus Cube with FocusMax with no problem, but then i can't connect with maximdl.
I cannot connect the focuscube with several programs at the same time. I would like to put the focuser position in each fitsheader of each image, but I would need to connect it with maxim dl.
Is there a hub driver of pegasus controller?
Regards from Catalonia!
Re: Control Focus Cube Maxim Dl/FocusMax
It works perfectly fine with any software that supports ASCOM, including MaximDL.
