Hello all,
does someone know a good source (dealer, vendor, etc.) for good custom made power cables?
I will use the UBPv2 with a third party power supply and for this I will need a custom cable connecting the 4mm banana plugs of the power supply with the UBP's XT60 connector (cable length >3m, up to 20A).
I searched the web and I could not find anyone offering customized cables, so maybe s/o has a good hint for me.
Stefan
Source for good custom power cables?
Re: Source for good custom power cables?
If you are a little bit handy, you can buy XT-60 plugs with short cables off Amazon. You can get banana plugs with cables from Powerwerx.com or West Mountain Radio. All you need to do is to connect the cables (solder them) and use heat shrink tubing to protect the connections.
Well, that's the issue, I am not really good in making stuff like this myself, therefore I am looking for someone who makes customized cables.
Stefan
Stefan
Why don't you contact us and tell us what you need?
Thanks for the offer, will do as soon as I know the exact required length.
Hi Evans,
just sent you an email.
Thanks in advance.
CS
Stefan
Thanks in advance.
CS
Stefan
