Is it possible to define point/degree of reverse rotation?
AstroHD
Post by AstroHD »
I have installed the Falcon Rotator in my image train. When operating the rotator I can see in my setup that it turns counter-clockwise until 220° when trying to move from there to e.g. 225° the rotator reverses direction to prevent cable problems and turns clockwise to the desired degrees. So far so good.
Question: Is it somehow possible to define at what point (or at what degrees) the rotator should reverse direction?
I'd like to set it to reverse direction at 190° instead of 220° for cable management reasons (the pack of cables would otherwise block the fan outlets of my cooled camera).
Thank you for any suggestion.
Herwig
cheers,
Herwig
astrohd.de
Re: Is it possible to define point/degree of reverse rotation?
Hi Herwig,
Unfortunately no, with the current firmware
The 220 deg is the hard limit.
However, we'll check how we can support that in a future firmware release.
Regards,
archer1960
Post by archer1960 »
I would like this capability too!
AstroHD
Post by AstroHD »
Thank you,
will follow the change log of future firmware releases :)
cheers,
Herwig
astrohd.de
