Comparison between Powerbox Series
Here is a handy comparison table that will help you to choose the appropriate powerbox for your needs.
FeaturePocketPocket AdvanceUltimate v2
12V Outputs44 +1 (Adj Out @ 12V)4 +1 Always ON Out + 1 (Adj Out @ 12V)
Switchable Outputs1 x 12V channel
1 x DSLR Out channel
1 x 12V channel
1 x variable output
4 x 12V Outputs
Adjustable Regulator
(Fixed 8V)
(3, 5, 8, 9, 12 Volt)
(3,4,5,6,7,8,9,10,11,12 Volt)
EXT Port (for peripherals)
Dew Heaters2 x Ports
2 x Channels
2 x Ports
2 x Channels
3 x Ports
3 x Channels
Auto Dew Heater Adjustment
Configurable per channel
Stepper Motor Controller
* Can accept external motor controller via EXT port)
* Can accept external motor controller via EXT port for 2nd motor drive)
Current Delivery10Amps10Amps20Amps
Power SensorsCurrent (12V + Dew Heaters) + VoltageCurrent (12V + Dew Heaters) + VoltageIndividual current meters for each output
Environmental Sensor
(included)
(included)
(included)
USB Hub
4 x USB3.0 Hub (unmanaged)
6 x USB3.1 Industrial Grade Hub.
Each USB Port can turn ON/OFF via software
Standalone Software
ASCOM SoftwareObserving Conditions,
Switches (upcoming)
Switches (upcoming)
Switches,
Focus
DC Input Socket2.1mm circular2.1mm circularXT60
ProtectionsReverse Polarity, 12V Overcurrent, OvervoltageReverse Polarity, 12V Overcurrent, OvervoltageReverse Polarity, 12V Overcurrent isolation per port, Overvoltage
Watchdog
Dimensions109mm x 74mm x 25mm
Weight 250 grams
100mm x 73 xx 25mm
Weight 300grams
120mm x 100mm x 30mm
Weight 400grams
