NYX-101 Harmonic Gear Mount
Harmonic Gear Drive on both axis
* Introductory Price
  • $2,960.00 (USD)
  • 2,960.00 + VAT (EUR)
Nyx, the ancient Greek goddess of the night, enlightened us to design and produce a high-performing, high payload mount that can easily carry imaging equipment up to 20 kg without needing a counterweight or shaft.
Strain wave drive on RA and DEC movement ensures a backlash-free operation with high torque at high payloads. A fully CNC machined aluminum alloy 6061 body, black and blue anodized, and a selection of branded parts (stepper motors, strain wave gear) inside the mount, ensure that Nyx-101 will perform flawlessly for many years. Mount includes an electronic brake on the RA axis to prevent backsliding when power is off as well as safety limit stops during slew or tracking.
Meet NYX-101
Our High Payload Harmonic Geared Mount
High precision strain wave gears
Harmonic Gears on Both Axis ensure high payload and a smooth, backlash-free operation.
A hybrid combination of a stepper motor & belt system along with sophisticated electronics can drive the RA axis down to 0.10 arcseconds of resolution
Reduction on the RA axis is 500:1 and 300:1 on the DEC axis.
Supporting high imaging loads
Counterweights are not required for weights up to 20Kg.
(counterweights can be installed for higher photographic loads)
Lightweight Design
Lightweight Design, compared to the payload of weight the mount can lift
CNC-machined aluminum alloy AL6061 used for aircraft makes the mount an excellent choice for your setup.
Mount weights 6.4 Kg
From a small refractor to a fully loaded SCT 11-inch telescope, NYX-101 can easily handle the payload
Equatorial or Altazimuth Mode
Mount can be used as a German Equatorial mount or as an Altazimuth, more suitable for visual observations
The mode can be switched from our PC or Mobile Application
Built-in Wireless & USB Control
NYX-101 supports wireless and USB 2 connectivity out of the box.
Both technologies can work simultaneously.
Mount is compatible with LX200 protocol and Sky Safari for mobile interaction
Power Off Brake
A safety power-off brake is installed on the RA Axis and provides an instant safe stop
during a planned or unplanned power interruption.
Additional Key Features
DC 12 Volts Battery Operation
NYX-101 requires 12V only for its smooth operation. This means that you can use your normal 12V battery without any additional converters. Mount consumes less than 0.6Amp during tracking and up to 2.5 Amps during slewing.
Secure power and USB
The power cable is a GX12 type with can securely lock onto the mount. USB type B special socket ensures a secure grip. Both of these sockets are placed on the non-movable part of the mount. No cables moving during slews and tracking. A second GX12 socket allows you to provide power to your imaging equipment.
Refraction Corrections
NYX-101 integrates a barometric sensor required to calculate atmospheric refraction corrections during mount tracking. For smaller focal lengths this might be overkill but if you have an SCT you will notice a welcome change in your guiding performance.
Universal Saddle Plate
NYX-101 includes a low profile and rigid universal Saddle that accepts Vixen and Losmandy 3-ich dovetails.
Integrated ST-4 Autoguiding Port
An ST-4 port is available at the back of the mount. Port is compatible with a simple hand controller or with an ST-4 guiding camera.
Polemaster Adapter
In the front of the mount, there is a place for the QHY Polemaster (adapter included), which allows you to perform a precise polar alignment, required for your imaging sessions.
Electronic assistant for initial polar alignment
A set of sensors allows you to orient the mount at the correct altitude and azimuth to have an initial, rough, polar alignment (for lower focal lengths such as camera lenses or visual observations ). Our mobile application guides you through that process.
Reverse Voltage Polarity Protection
NYX-101 has been designed with reverse voltage polarity protection. A saver if you accidentally reverse voltage or battery polarity during the night.
Optional Counterweight support
Mount does not require counterweights for payload up to 20Kg. However, if you would like to install counterweights for higher payloads there is a compatible M12 threaded shaft hole at the end of the DEC axis.
ASCOM, INDI, Sky Safari Support
The mount fully supports ASCOM 6 and INDI framework. Sky-Safari is also supported allowing you to control the mount through your mobile device.
LX200 Compatibility
LX200 protocol is fully compatible with NYX-101. Sky-Safari works out of the box with the mount.
Mobile Control
A mobile application for IOS and Android platforms allows you to control both axes of the mount, slew to installed catalogs of thousands of night sky targets and do a rough polar alignment through an electronic polar assistant.
Safety limits on RA axis
Safety limit encoders on RA Axis prevent internal cable snag or collision with the tripod.
Firmware Upgrade
An easy firmware upgrade process allows you to stay up to date with bug fixes and the latest features of the mount.
Optional Accessories
Pegasus Carbon Fiber Tripod
This is the Pegasus Carbon Fiber Tripod for NYX-101 Harmonic Drive Mount (PEG-TRPD101).
The tripod legs are rigid and lightweight, made from carbon fiber. We strongly suggest using this tripod with imaging equipment for up to 15 kg.
  • Length Retracted: 65 cm
  • Max length: 120 cm
  • Weight: 2000 gr
  • Max Load Capacity: 50kg
  • Angle of Legs: 35° Fixed
In the box:
  1. Carbon Tripod
  2. Carbon Tripod Adapter
  3. Carry / Store bag
  4. 2 x Alen Hex Keys
  5. Metallic (3 pcs) spikes to replace rubber shoes
Half Pier Extension 180mm
A pier extension (+18 cm / 7” is available). The pier can be easily constructed by purchasing the three (3) following parts:
  1. EQ6 / Universal adapter
    (PEG-ADAPT101-EQ6)
  2. Aluminum Standoffs – 3 pcs
    PEG-ADAPT101-STDOFF)
  3. Carbon Tripod Adapter
    (comes along with our Carbon Tripod)
    PEG-TRPD101).
Note 1: If you do not own the carbon tripod then the EQ6 / Universal Tripod Adapter can be doubled to assemble the half-pier extension.
Note 2: Three (3) additional standoffs can be purchased to increase pier stability
(Half Pier accepts up to 6 standoffs).
Adapters
Tripod Adapter
NYX-101 Carbon Tripod Adapter
(Included in Carbon Tripod)
NYX-101 EQ6 / Universal Adapter
PEG-ADAPT101-EQ6
*Note: The azimuth dowel installed in the photos above is included in the mount package.
3 standoffs6 standoffs
Half Pier with 3 or 6 standoffs.
(Mouse hover to view)
Assembly / Usage Scenarios
Note: You also have the option to discard the pier extender and place the NYX-101 directly on a tripod/pier by using only the Universal /EQ6 Adapter (PEG-ADAPT101-EQ6)
This scenario is most appropriate when you have a small refractor setup that does not require a pier extender
NYX-101 with Pier Extention on an Aluminium (EQ6 Compatible) Tripod
This is a classic example of using your Aluminium EQ6 Tripod with our Half Pier Extension along with 2 x PEG-ADAPT101-EQ6 adapters.
The real deal!
We loaded a refractor (A Takahashi FSQ85-ED @ 450mm) on the NYX-101 harmonic geared mount and a CMOS camera QHY268C along with other astrophotographic equipment. The payload was 8 kg / 17.6 lbs. Guiding was achieved via an off-axis guider and QHY-5III Series camera.
Moreover, we tried the extreme scenario and loaded our Celestron EdgeHD 11”with imaging equipment. (Prodigy Micro focuser, QHY268M, QHY-OAG, QHY 5III Guiding camera Pegasus Indiigo 7 pos Filter Wheel) in our backyard. The total payload is 18Kg and the focal length remains default at 2800mm.
The real deal is the two images below from our actual tests during long cloudless nights.
  1. An image from NINA with unguided results from an 120-sec exposure at 2800mm
  2. PHD2 guiding graphs from the OAG guider. The guiding exposure interval is every 2 seconds.
Unity Platform
NYX-101 mount is controlled and fully configured through our Unity Platform via USB or Wi-FI channel. The included ASCOM driver supports multiple clients.
NYX-101 Harmonic Geared Mount
Power Supply 12V / 5A with GX12 jack
Soft Case Carry Bag
USB2 Type A to B Cable
Azimuth Dowel
NYX Hand Controller
NYX-HC
NYX Hand Controller offers access to essential features, enabling users to effortlessly access mount information, swiftly navigate to precise coordinates, and explore renowned celestial targets and catalogs.
Cigarette Lighter Adapter to GX12 (1.8m)
CIGLIGHT-ADAPTERGX12
Use this cable to provide power to NYX-101 by using a battery pack
Adapter 2.5mm x 5.5mm female to GX12 female (30cm/1 ft) PEG-ADAPT-25GX12
If you own a PEG-PSU-25 you can convert the 2.5mm socket to GX12 and provide power to NYX-101
Power cable 2.1mm Male to GX12 female
PEG-CABL-GX12
If you own a PegasusAstro Powerbox use this cable to provide power to NYX-101 mount
Frequently Asked Questions
Mechanical Drawings
NYX-101 Dimensions
Pier (EQ6) Adapter Mechanical
Pier (EQ6) Adapter Mechanical Drawing
Material CNC machined 6061  aircraft aluminum alloy
Mount Mode Equatorial or Altazimuth
Mount Drive Strain Wave (Harmonic) Gear and Belt resulting reduction 500:1 (RA) and 300:1 (DEC)
Load Capacity 20 Kg without counterweights
30 Kg with counterweights
Weight 6.5 Kg
Safety / Power Off Brake On RA Axis
Dovetail Vixen and Losmandy 3-inch
RA Motor Resolution 0.10”
Max Slew 6 degs/sec
Power Voltage 12V DC unregulated
0.7A during tracking, 2Amps during slewing
Guide Port ST4
Counterweight Shaft M12 Shaft (1.75mm pitch)
Communication Wireless 802.11g and USB2
Operating Temperature -20° to + 50°C
Warranty 3 years
Made in (designed, assembled and tested) Greece. We carefully curate the entire manufacturing, testing and packing process.
