Mounting Accessories
A-Plate
SKU: PEG-APLATE
Accessories Plate can be mounted on top of your telescope and accept a wide range of devices such as one of our Powerbox Series, a USB Hub, or any other device in the market.
The plate is made of black anodized aluminium and its thichkness is 5mm. Weight is 400g
The plate includes multiple rails allowing you to orient devices at your preference.
An example of the Acessories Plate mounted on a Skywatcher Esprit 100ED.
Thichkness is 5mm. Weight is 400g
Pair of Black Aluminium Dovetail Brackets for UPBv2
SKU: PEG-BRACK-UPBv2
Mounting Brackets for the Ultimate Powerbox v2 allows you to place the device onto a Losmandy 3” or a Vixen plate.
Small Factor PC Top Plate for UPBv2
SKU: PEG-PLATE-UPBv2
Top Aluminium Plate for Ultimate Powerbox v2 allows the mounting
of a small factor PC such as an Intel NUC
Small Factor Top Plate for PPBADV
SKU: PEG-PLATE-PPBADV
Top Aluminium Plate for Pocket Powerbox Advance allows the mounting of additional equipment (E.g A small factor PC such as Intel NUC )
Pair of Black Aluminium Dovetail Brackets for PPBADV
SKU: PEG-BRACK-PPBADV
Pair of Mounting Brackets for Pocket Powerbox Advance
