Intelli Flat
 Intelli Flat device will provide duty cycle power to your flatbox. Only a single USB cable required and control of brightness can be remote using a PC and supplied software or manual using the knob on the top of the device.
intelli flat
One cable connection
The Intelli Flat was designed to be operated by a single cable. Just connect the USB cable into your computer or USB hub. The required power to light on your flatbox will be received by this single cable.
Manual operation
There is a built in option to use the dimmer on the top of the Intelli Flat and manually set the brightness of your flatbox. Manual and PC Operations can co-exist.
PC Remote operation
Of course the term “Intelli” comes from the remote operation capability. Software is provided to control the controller. You can also store your Luminance per filter settings and retrieve them back.
No driver required
Just install the software and it will auto recognize the device. You don’t need to install any driver. It will plug and play out of the box.
intelli flat
1 Year warranty
For the Intelli Flat controller
Compact size
Dimentions: 66 x 66 x 28 mm
What is inside the box
  • 1 x Intelli Flat Device
  • 1 x USB type B cable (1.8m length)
  • 1 x RCA to 2.1 DC cable (1.8m length, center positive)
Technical Specifications
Supply Voltage USB Powered (5V DC / USB input)
Power Output Connector RCA Connector (12V DC /  Duty Cycle PWM power)
Output Max Current 500 mA
Dimensions 66 mm x 66 mm x 28 mm
Order Intelli Flat – 99 € [wp_cart_button name=”Intelli Flat” price=”99″ shipping=”5″]
